1st Time Installation problems
Discussion in '3CX Phone System - General' started by diablorick, Jun 23, 2009.
  1. diablorick
    Jun 23, 2009
    I am trying to install 3CX for the first time. I am using a windows 2003 server that I originally used for DB testing. The only program I had installed on it was MS SQL and I uninstalled that before starting the 3CX install. Now when I try to install, it says port 5480 is open and must be closed before installing. When I check the port, it says it's listening and shows as "System" only. No program or service is using it, just "System". I tried to use CurrPorts to close it, but it won't close.
    Any help would be greatly appreciated.
    Thank you!!!!
  2. diablorick
    Jun 23, 2009
    OK, I uninstalled IIS and then the port closed. I then re-installed IIS and the port stayed closed so I am not sure why but it works now.
