Solved 1yr free pbx console down
Discussion in '3CX Phone System - General' started by Garyy, Feb 21, 2018.
  1. Garyy
    Feb 21, 2018
    My free 1yr 3cx with your google cloud is down.. how to "reboot" it?
    ixelia.3cx.fr
    Best Regards
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,375
    84
    Hi Garyy,
    I checked the VM you had created and it seems to have been deleted due to inactivity.
  3. Garyy
    Feb 21, 2018
    arf..could you recreate it...?
  4. NickD_3CX
    Jun 2, 2014
    1,375
    84
    Unfortunately not, that is the purpose of the footnote on the page:
  5. Giuseppe A
    Feb 22, 2018
    I'm trying 3cx on 3CX Google Cloud and the dashboard sometimes goes down:
    chumbalasrl.3cx.it
    Following service(s) were stopped recently:
    3CXPhoneSystemMC01 (10.156.2.89)
    and only after a couple of hours it restarts.
    Is there any way to set a static IP, and access Google Cloud Platform with "Let 3CX host you" slected during installation of 3cx pbxexpress?
    Regards
    giuseppe
  6. NickD_3CX
    Jun 2, 2014
    1,375
    84
    In GC Platform generally Static Public IP is an option, but the instances that are created when 3CX is hosting it for you will not, it will always be "Ephemeral" as Google calls it. That is why the Public IP type in the 3CX Management Console should be set to "Dynamic".
    SSH access is also not possible when you are using the 3CX hosting option.
