2.0 Beta not allowing incoming calls
Discussion in '3CX Phone System - General' started by bduke08021, Jul 22, 2009.
  1. bduke08021
    Jun 20, 2009
    34
    So i can make outgoing calls. when i call my skype number, the status on the gateway changes for less than a second and returns to on hook status. Simply put, it picks up then hangs up in under a second. The pbx is allowing inbound calls on this line. Out of Ideas, any help wpuld be great. My OS is Vista.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    Sounds like the "end call" being set in the PBX corresponding PSTN gateway - check this.
    Also, on the gateway, there are more ports using the same Skype account?
    Regards
    vali
