2.04 incoming call via wireless
Discussion in 'Android' started by owen.watson, Jun 15, 2012.
  1. owen.watson
    Jun 15, 2012
    Device Info
    Phone Model: Samsung Galaxy S2
    Firmware Version: 2.3.3
    Issue Info
    Handset: Phone
    Contacts: [Local|Exchange|Google] ?
    Connection: WiFi (g)
    Server: External
    When receiving calls, occasionally I can hear the caller fine, but they can't hear me.
    11,117
    329
    You state Server:external...which VoIP provider are you using the phone with? Someone else may have the same issue/solution.
    Have you tested on more than one hotspot?
