2 broadband providers on 1 network?
Discussion in '3CX Phone System - General' started by h2009, Aug 4, 2008.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    You could use a load balancing router - i.e. set certain traffic i.e. SIP to one connection and all other traffic to another.
    The other option is to allow 2 networks to run (VLAN) and send the VOIP lan over to another connection, best done via hardware
    have a look at monowall (i've heard that this can be used to both options above)
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Oh in addition,
    does your client need two connection?
    The reason why i ask this is because since i've put in QoS and CoS, i've never looked back at it. My situation was getting to point where i was so sure i need more than 1 broadband connection i start to install another, but after putting in QoS and CoS on the brand new layer 3 Netgear switchs its completely removed any kind of need for this.
