2 NEW Issues on existing V14 system.
Discussion in '3CX Phone System - General' started by Pete Gazda, Dec 26, 2017.
  1. Pete Gazda
    Dec 14, 2017
    12
    Hello
    DTMF tones just stopped working. Unable to retrieve voicemail from Yealink T46G phone. Light is on but after hitting VM button, unable to enter password.
    2nd Issue, Inbound caller cannot hear the 3CX user.
    1. Nothing changed on network
    2. Firewall checker came back clean
    3. Reboot physical server
    4. Speedtest 50 down 11 up
    5. Phones rebooted too
    Not sure why it would work for over a year then suddenly flake out.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Please try next steps:
    1. Reboot the phone and try again
    2. Reset the phone to factory default, re-provisioning it and try again
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,362
    535
    Hello @Pete Gazda
    Please note that V14 is no longer supported as mentioned here, so i would first upgrade to V15.5 and see if you can replicate your issue there.
  4. Pete Gazda
    Dec 14, 2017
    12
    Hello Yiannish,
    Customer is afraid to upgrade because of other things working now that will not work after upgrade. We ran into issues before such as call forwarding from phones that require a custom template to correct then you will not support then anyways
  5. Pete Gazda
    Dec 14, 2017
    12
    Reboot and re-provision does not work. It has to be something global as all extensions are experiencing the same issue.
  6. leejor
    11,095
    327
    Do you see any error (or concerning) messages in the Activity logs? Have you tried retrieving voicemails from devices other than Yealink sets (ATA using an analogue set, or 3CX client)?
    If you call another extension, then press some number keys, does the other end hear DTMF?
    Is the PBX local to the sets?
    Is it just external calls experiencing the one way audio? Do you just have the one trunk group? Gateway, SIP?
