2 NICS in phone server
Discussion in '3CX Phone System - General' started by megatech, Nov 2, 2009.
  1. megatech
    Oct 19, 2009
    14
    I have 2008 server with 2NICS.
    primary card is 192.168.44.249 with default gateway pointing to 192.168.44.1 (DSL Router/FireWall)
    secondy card is 192.168.88.249 with default gateway pointing to 192.168.88.1 (DSL Router/FireWall)
    when a call is made the phone system routes via 44.1 but I want it to go via 88.1
    both routers have fixed ip addresses. 3cx is setup with stun. if I turn stun off and set the intefarce ip and external address it works when i use 44.1 and it's public ip, but not when is use 88.1 interface and it's public ip. Therefore, I assume all routes are being sent via the default gateway of the primary nic.
    I can't find a setting for 3cx to use a specific interface for a SIP trunk.
  2. StefanW
    Jun 2, 2009
    1,210
    84
    yes, but this is windows and not 3cx.
    have u seen the small warning when u entered the second gateway to the second network card?
    Under the adv. networks settings u can select the order of ur network card and only one gateway, the one at first in the list will be used as gateway and outbound rule for 0.0.0.0...
