2 Phone Numbers
Discussion in 'Call Flow Designer' started by Lee Parvin, Oct 13, 2017.
  1. Lee Parvin
    Oct 13, 2017
    Hi there
    If we have a SIP trunk with 2 phone numbers mapped to it eg Geographical number and a UK 0800 Freephone Number.
    Is it possible to intercept which inbound number was called and therefore have different flow patterns accordingly??
    Lee
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    managment console
    inbound rules
    add CID rule
  3. leejor
    11,097
    328
    Won't CID simply show the callers number? Wouldn't you have to make use of DID information, if sent (subscribed to)?
    ...unless CID numbers coming from each source have (perhaps) a unique prefix, that can be used to identify, and separate them.
    #3 leejor, Oct 13, 2017
  4. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Sorry, I'm multitasking and not using my full brain.
    You are correct. Its DID rule.
    CID would be based on Callers ID.
    Actually, I'm in Tampa at 3CX training, ha ha.
  5. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    That is correct, in the 3CX console you need to define DIDs for each number, and route these calls to the CFD app. Then, in your CFD app, you can use the variable "session.did" to determine the number dialed by the caller, and proceed with a different flow depending on that.
    Kind regards.
  6. Lee Parvin
    Oct 13, 2017
    Many thanks for the support. Much appreciated for your input.
    Lee
