2 remote locations that cannot talk to each other
Discussion in '3CX Phone System - General' started by daktur, Apr 13, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Hi all, here I am again.
    I have a client with 2 buildings / different network.
    Each network can communicate internally but when trying to call between networks the calls so not go through.
    There is no relevant log error.
    I advised him to use the firewall checker but since outgoing calls are working fine, I am afraid he is not getting any errors.
    He is using an unsupported phone.
    Any clues?
    Thanks again.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    hello @daktur
    How are the phones provisioned? Where is the PBX located?
  3. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    The phones are provisioned manually since they are unsupported.
    The first extension I have configured seems to be working fine.
    The box is locate in Netherlands and all extensions distributed between Brazil and the middle East so there are no local extensions.
    The other extensions in the same buildings running 3cx softphone using tunnel work fine.
    Thanks again.
  4. YiannisH_3CX
    May 10, 2016
    5,425
    352
    Try calling voicemail or *777 (echo test). does that work? Have you tried enabling PBX delivers audio under extension settings? Does that make a difference?
  5. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    The wierd thing is that the extensions can make outbound calls and can call each other in the same network.
    The main problem is that the phones don't ring at all. But when they ring everything works fine.
    Ports 5000 and 5001 are blocked on the firewall. Does it affect anything when not using tunnel?
    On the provisioning tab in the pbx it shows 3cx softphone. Do I have to change something there?
  6. saqqara16
    Jan 13, 2016
    43
    5
  7. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    They are connected via internet.
    I though about the SBC but I understand it was only for 3cx softphone.
    Is it worth to give a try?
  8. saqqara16
    Jan 13, 2016
    43
    5
    No , SBC for hardphones as well - this overcomes all NAT issues and ports
    Definitely worth a go
  9. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    I will try and update you, where can I find the tunnel password?
    I am kinda lost with v15 cnfig locations.
  10. YiannisH_3CX
    May 10, 2016
    5,425
    352
    The password can be found at: Settings / Security / 3CX tunnel
  11. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    The computer where SBC is running have to be on all the time? Or once it's configured there is no need to keep the comouter running?
  12. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,036
    153
  13. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    That means I will have to configure them like this:
    Proxy: "Server address / IP
    Port: Server SIP pory
    Outbound Proxy: "SBC computer IP"
    Port: Tunnel Port
    Correct?
    Thanks again.
