2 single FXO gateways??
Discussion in '3CX Phone System - General' started by woodduck, Jun 15, 2007.
  1. woodduck
    Jun 15, 2007
    6
    Is it possible to use 2 single FXO gateways instead of 1 gateway with 2 FXO ports.
    I am trying to set up a demo system in my home office and want to do it as inexpensively as possible.
    Thanks for the help.
  2. sittsh
    May 2, 2007
    19
    yes it is i do it with zoom 5801 ata its cheap and has 1 fxs and 1 fxo jack
    and it works good the only limitation i have is no caller id sent to 3cx server but besides that it works fine with 3cx and all features seem to work with it.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Grandstream HT-488 also. It works fine for 3CX PBX. FXS port can decode caller ID for internal extension. PSTN caller ID may be cannot.
