Solved 2 SIP Trunks, 2 Ring groups, still all go to 1 ring group
Discussion in '3CX Phone System - General' started by Michael Torfs, Jan 29, 2018.
  1. Michael Torfs
    Jan 23, 2018
    30
    I have 2 SIP trunks configured, both Sip trunks are configured to route call to 2 different Ring Groups.
    Still all calls form the 2 trunks are being routed to 1 ring group.
    I tried inbound rules, but this made no difference. Currently no inboud rules exist.
    What info should I provide to be able to check for a solution?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    The only setting you need to setup, is 'Route calls to' settings under the SIP configuration
    What does the activity log file, tell you
    Also check Contacts -> Options -> you select Append Name or Prepend Name (this will show the Ring Group Name)
    #2 Saqqara, Jan 29, 2018
  3. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    You HAVE to have inbound rules. That's how the PBX routes calls.
    3cxnub likes this.
  4. Michael Torfs
    Jan 23, 2018
    30
    Do I really? Since in the SIP trunk configuration you can already route the incoming calls to a ring group.
  5. Michael Torfs
    Jan 23, 2018
    30
    My activity log says the following to a call I just did from my mobile. It says it failed, but actually I did not fail, it did came in and was answered, I could talk:
    01/29/2018 6:41:00 PM - [CM503003]: Call(C:6): Call to <sip:00@immonatie.3cx.be:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
    01/29/2018 6:41:00 PM - [CM503003]: Call(C:6): Call to <sip:01@immonatie.3cx.be:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
    01/29/2018 6:41:00 PM - [CM503003]: Call(C:6): Call to <sip:00@immonatie.3cx.be:5060> has failed; Cause: 487 Request Cancelled/INVITE from ##:5065
  6. Michael Torfs
    Jan 23, 2018
    30
    Just tried creating inbound rules again, the behaviour stays the same.
  7. Brian Cross
    Jul 26, 2017
    109
    27
    There should be two inbound rules with this strategy that is created when you setup the trunk.
  8. Michael Torfs
    Jan 23, 2018
    30
    When I just created the SIP trunks, there are no inbound rules automatically created.
  9. Michael Torfs
    Jan 23, 2018
    30
    Here are the inbound rules and 2 SIP trunk configurations.
    Calls always route to the first Ring Group: ImmoNatie RG
    Screen Shot 2018-01-29 at 18.54.48.png Screen Shot 2018-01-29 at 18.54.26.png Screen Shot 2018-01-29 at 18.54.04.png
  10. leejor
    10,752
    285
    Are these separate trunk groups, or two members in one trunk group? If it is one group, then all calls will go to the one route(destination), unless you are making use of DID routing, or basing routing on caller ID.
    The log you posted shows calls being cancelled from the RG members that didn't answer, that's normal.
  11. Michael Torfs
    Jan 23, 2018
    30
    I have 2 ring groups with each 2 extensions... See below
    Screen Shot 2018-01-29 at 22.39.18.png Screen Shot 2018-01-29 at 22.37.53.png
  12. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Michael Torfs
    As @leejor said, please clarify if those two numbers are two separate sip trunk accounts, or if they are DIDs of the same sip trunk.
  13. Michael Torfs
    Jan 23, 2018
    30
    there a separate sip trunk for each number. See below
    Screen Shot 2018-01-30 at 09.01.51.png Screen Shot 2018-01-30 at 09.01.34.png
  14. mariosM_3CX
    Nov 1, 2017
    406
    38
    Let's simplify things first to isolate the issue. Can you please try and forward each number to a different extension, instead of Ring Groups? (registered, available extensions)
    Let's see what happens in this case.
  15. Michael Torfs
    Jan 23, 2018
    30
    I did some isolating
    • removed trunk ending on number 32453, only trunk with number ending on 32442 exisits, see config below
    • call number 3232848888, Eveline's phone rings: perfect
    • call number 3236890809 that is connected to trunk 32453 from the providers side, indeed, busy tone since the provider cannot reach the 3cs server (trunk deleted)
    • red-added trunk ending on number 32453, coonected to Michael's extension (2nd config below)
    • call on number 3232848888 (trunk 32442) still goes to Eveline
    • call on number 3236890809 (trunk 32453) also goes to Eveline, this is not ok
    Screen Shot 2018-01-30 at 11.10.53.png Screen Shot 2018-01-30 at 11.17.29.png Screen Shot 2018-01-30 at 11.17.53.png
  16. Michael Torfs
    Jan 23, 2018
    30
    further isolating.
    I deleted the IN trunk (32442), then calling 3236890809 goes to my extension (Michael's)
    Meaning trunk 32453 work when it is the only trunk in the configurations, it goes to the wrong extension when the second trunk is configured.
    Can the reason be in the inbound parameters, maybe the call source identification, see below? I did not change these, this is what 3CX sets when selecting BE-Weepee provider:
  17. mariosM_3CX
    Nov 1, 2017
    406
    38
    Assuming that both trunks are from the same vendor, try to disable Call source identification and see if it fixes the issue
  18. mariosM_3CX
    Nov 1, 2017
    406
    38
    As shown below, weepee has only Single account support, so that's why you are experiencing this behaviour.
    What you can try, is to enable the option "Use both "Source Identification" rules and "Caller Number/Name" field mappings" in the Inbound rules as shown below.
    Also, make sure that except from the main numbers, you have all your DIDs configured in their trunks for this to work.
    Michael Torfs likes this.
  19. Michael Torfs
    Jan 23, 2018
    30
    That did the trick, thx a lot.
  20. mariosM_3CX
    Nov 1, 2017
    406
    38
    You're welcome, glad to help.
