- Joined
- May 8, 2007
- Messages
- 11
- Reaction score
- 0
Primarily I have switched from 1stage dialling to 2 stage dialling.
Immediate support required is in opitmumly configuring the gateways for 2 stage dialling.
If i am using and dialling using Xlite using the 2 stage dialling method thru the PSTN gateway GXW4108 I am able to dial , hear call progress tones and succesfully place calls too.,
If I am using GXW4008 and dialling out using the 2 stage dialling method I get to hear the dial tone on pressing 0#.
on attempting to dial out the number after i get the PSTN dial tone , there is allways a failure.
1) sometime I get busy tone
2) sometimes i get connected to wrong numbers.
summary: the tones are never interpreted by the server / gateway correctly
3CX log generates an error saying:
21:13:31.093 StratLink:nHangUp [CM104001] Call(234): Ext.132 hung up call; cause: BYE; from IP:192.168.1.161
21:13:25.656 MediaServerReporting:TMFhandler [MS211000] Call(234) Ln:10000@AIRTEL: DTMF (in-band) from 192.168.1.160:5004 detected.
21:13:22.390 MediaServerReporting:TMFhandler [MS211000] Call(234) Ext.132: DTMF (RTP) from 192.168.1.161:5020 arrived. in-band DTMF tone detection is turned off.
21:13:20.812 CallLegImpl:nConnected [CM103001] Call(234): Created audio channel for Ln:10000@AIRTEL (192.168.1.160:5004) with Media Server (192.168.1.70:7418)
21:13:20.812 StratInOut:nConnected [CM104005] Call(234): Setup completed for call from Ext.132 to Ln:10000@AIRTEL
21:13:20.812 CallLegImpl:nConnected [CM103001] Call(234): Created audio channel for Ext.132 (192.168.1.161:5020) with Media Server (192.168.1.70:7416)
21:13:20.812 CallConf:nProvisional [CM103003] Call(234): Ln:10000@AIRTEL is ringing
21:13:20.609 CallConf:nIncoming [CM103002] Call(234): Incoming call from 132 (Ext.132) to sip:[email protected]
I do not understand this language
awaiting immediate and positive response
girish
girish
