*20* LinkSYS SPA3102
Discussion in '3CX Phone System - General' started by galal202, Jul 5, 2008.
  1. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello
    pickup call *20*
    page code *9+extension
    does not work from spa3102 and spa962
    it works from grandstream 2020
    doen any one help please ?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Dial Plan setting issue at your SPA. You may try to change it by default "(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)"
    to
    "(*xx*|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)"
    or delete any unwanted setting. eg delete *xx
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    I wrote a bit of a guide a while back.
    http://www.d-d-d.com.au/3cx/InstructionMSPA3102V2_2a.pdf
    Try that, see if it helps, if not let me know.
    H.
  4. ess
    ess New Member
    Jun 8, 2007
    133
    just to clarify... this is an issue on the spa962 phone's dial plan. look at the following guide, specifically point 13:
    http://www.3cx.com/sip-phones/linksys-SPA-921.html
    Although this allows this * features to work, it introduces a new problem where there is only a 2 second delay before dialing times out.
    Let us know how it goes.
  5. Henk
    Henk Member
    Nov 13, 2007
    250
    Can you setup a digtal mask on that phone?
