2008 Web Server Question?
Discussion in '3CX Phone System - General' started by etj, May 26, 2010.
  1. etj
    etj
    May 21, 2010
    Was wondering what limitation in 2008 Windows Web Server, that prevents you from running 3CX on IIS?
    Regards,
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    No limitations. It works well for us. The only thing we have not tried is Fax and I think it will probably not work.
  3. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Same here I was even running it on Windows 2008 beta
