2008R2
Discussion in '3CX Phone System - General' started by noshali, May 10, 2010.
  1. noshali
    May 10, 2010
    5
    I installed it on Windows Server 2008R2. All went well. When I do localhost:5484 I get the following. I get the same trying to access it from other pcs as well.
    Thanks & Regards,
  2. noshali
    May 10, 2010
    5
    Tried this on a windows 7 machine and works fine. I think it has to do something with browser security. I am not sure...just guessing.
    regards,
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,578
    115
    The port 5484 is the IVR port of the PBX. The IVR is Xml based so it's natural that you are seeing that when you try to access it.
    If it's the Management console you are trying to access you better try : Start > Programs > 3CX Phonesystem > Management Console or the Windows Management Console located in the same directory.
  4. StefanW
    Jun 2, 2009
    1,230
    95
    or use the port 5481
  5. noshali
    May 10, 2010
    5
    Thanks.
    Port 5481 does not work but the management link works now. It was not working yesterday.
    regards,
  6. pjr
    pjr New Member
    Oct 5, 2009
    154
    You may have encountered this issue
    http://www.3cx.com/blog/docs/management-myphone-blank/
    Paul
  7. noshali
    May 10, 2010
    5
    Yup that is what initially happened so I went in to IIS and clicked on the site that was created which took me to port 5484.
