24 port analog gateway
Discussion in '3CX Phone System - General' started by business54, Mar 7, 2017.
  1. business54
    Apr 20, 2016
    56
    Has anybody put in the Patton 24 port FXS gateway? I see the 3CX has the template for the Welltech WellGate 24 port but we prefer Patton products. We are running 3CX ver. 15.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @business54
    You will need to contact Patton to provide you with a template for your device and navigate to C:\ProgramData\3CX\Instance1\Data\Http\Templates\fxs
    and place it in there. Then restart the management console service and the device template will appear in the management console.
  3. 3CXDude
    3CXDude New Member
    Oct 1, 2015
    105
    26
    I have a few of them on a system. Good units.
    3CX had supported templates for them in V12.5 but I haven't seen them in V14 or V15 for some odd reason.
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    [Edited due to a complaint]
    ... If you go with Patton I can send you one of my config files, you'll just need to replace the extension numbers, registration passwords, and server IP address (pretty easy with a search and replace).
    #4 JasonNadeau, Mar 7, 2017
  5. business54
    Apr 20, 2016
    56
    Has anybody used the WellTech gateways? They seem quite a bit cheaper than the Patton but I'm sure it's for a reason.
