2N Helios
mes8579
Is the 2N helios IP Vario door phone supported by the 3CX phone system. Does not show as specificaly suppored but neither do most.
If it is a SIP compliant device, and you are able to manually configure it (and have some understanding of SIP), then it should work, especially if it is on the same network as the PBX. If it isn't listed as "supported" then it hasn't been tested, nor will any official support, be offered.
Getting Started - Admin
damiano giannini
Get 3CX - Absolutely Free!
3CX
