2nd call comes in, 3CXPhone "decline" drops call
Discussion in 'Windows' started by 3CXusername, Oct 14, 2014.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    This issue is only replicated when 3CXPhone (v12.0.37098) is only running on the Windows taskbar – if minimized or open you will not see the “pop-up” that is required for the Access\Decline\Divert-to-VM options.
    It seems this does not work properly with the T46g (FW v28.71.0.224 and v35.73.0.16) but does with the T48g (35.72.0.255)
    Results
    T46g-
    Accept- Does nothing – no answer (caller rings out)
    Decline- takes the new caller and drops the existing call
    Divert-to-VM- works, sends the new caller to VM and keeps the existing call intact
    T48g-
    Accept- holds the existing call and answers the new caller
    Decline- rings out the new caller – existing call is unaffected
    How can we get the T46g to work as the T48g?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Question : does the extension have option / Forwarding rules / Available / "I want to be able to accept more than 1 call at the same time - uses Phones status" ticked? if not please adjust and retry.
    Are the yealink provisionned, 3CXPhone provisionned using welcome email?
  3. 3CXusername
    Jul 31, 2014
    183
    16
    Hi Pierre,
    Thanks for your response.
    Same settings for extension with T46 (issue) and T48 (no issue)
    1. Extension set to 'Available'
    2. No Forwarding rules
    3. "I want to be able to accept more than 1 call at the same time" - is enabled
    4. Yealink T46 and T48 are both provisioned from 3CX
    5. 3CXPhone provisioned using welcome email
    Any other suggestions? Can you recreate?
    thanks.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    Wonder if this has to do with the error here:
    http://forum.yealink.com/forum/showthread.php?tid=2430
  5. relion
    Nov 8, 2014
    10
    We made a custom app for 3cxphone to display caller ID and we have the same problem. It double calls the app only for queue calls....
    Any 3cx folks out there that want to comment?
    Thanks, Adam
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi relion, was this reply related to same topic?
