2nd Outbound call failing
Discussion in '3CX Phone System - General' started by Marcus99, May 16, 2016.
  1. Marcus99
    May 16, 2016
    Greetings
    Our business outbound calls through the Patton are having issues. Any individual user can ring outbound from their handset without problems however as soon as a 2nd user attempts to call out at the same time/during the other call they get approximately 15 seconds of nothing then an engaged signal.
    I've Isolated the moment it happens and posted the logs of it below. It reports a 504 server error, however scanning the forums I've been unable to find another with the exact same error.
    Any help would be greatly appreciated, Thanks in advance.
    Marcus.
    16-May-2016 08:28:39.680 Leg L:837.2[Line:10002>>0438615208] is terminated: Cause: 504 Server Time-out/INVITE from 192.168.15.20:5062
    16-May-2016 08:28:39.680 [CM503025]: Call(C:837): Calling T:Line:10002>>0438615208@[Dev:sip:10003@192.168.15.20:5064,Dev:sip:10004@192.168.15.20:5066] for L:837.1[Extn]
    16-May-2016 08:28:39.677 Call to T:Line:10002>>0438615208@[Dev:sip:10002@192.168.15.20:5062,Dev:sip:10003@192.168.15.20:5064,Dev:sip:10004@192.168.15.20:5066] from L:837.1[Extn] failed, cause: Cause: 504 Server Time-out/INVITE from 192.168.15.20:5062
    16-May-2016 08:28:39.677 [CM503003]: Call(C:837): Call to <sip:0438615208@192.168.15.20:5062> has failed; Cause: 504 Server Time-out/INVITE from 192.168.15.20:5062
    16-May-2016 08:28:36.788 Currently active calls - 2: [836,837]
    16-May-2016 08:28:28.700 [CM503025]: Call(C:837): Calling T:Line:10002>>0438615208@[Dev:sip:10002@192.168.15.20:5062,Dev:sip:10003@192.168.15.20:5064,Dev:sip:10004@192.168.15.20:5066] for L:837.1[Extn]
    16-May-2016 08:28:28.651 [CM503027]: Call(C:837): From: Extn:107 ("Marcus" <sip:107@192.168.15.1:5060>) to T:Line:10000>>0438615208@[Dev:sip:09628233@202.142.143.234:5060]
    16-May-2016 08:28:28.651 [CM503004]: Call(C:837): Route 3: from L:837.1[Extn] to T:Line:10000>>0438615208@[Dev:sip:09628233@202.142.143.234:5060]
    16-May-2016 08:28:28.651 Line limit check: Current # of calls for line Lc:10000(@AussieBB[<sip:09628233@202.142.143.234:5060>]) is 0; limit is 3
    16-May-2016 08:28:28.651 [CM503027]: Call(C:837): From: Extn:107 ("Marcus" <sip:107@192.168.15.1:5060>) to T:Line:10002>>0438615208@[Dev:sip:10002@192.168.15.20:5062,Dev:sip:10003@192.168.15.20:5064,Dev:sip:10004@192.168.15.20:5066]
    16-May-2016 08:28:28.651 [CM503004]: Call(C:837): Route 2: from L:837.1[Extn] to T:Line:10002>>0438615208@[Dev:sip:10002@192.168.15.20:5062,Dev:sip:10003@192.168.15.20:5064,Dev:sip:10004@192.168.15.20:5066]
    11,095
    327
    Is it always calls to port 5062 that fail, or is it random?
    If it is always to 5062 then check the gateway settings, for that port, and the phone line attached.
