3 cx configuration
Discussion in '3CX Phone System - General' started by hiramesh88, May 29, 2012.
  1. hiramesh88
    Mar 3, 2012
    I am using sanghoma gateway to use 3 cx for my pstn line. I face a lot of problems, NBE crashes, when the call limit is exceeded Sanghoma crashes all leading to outage of more than a day. Is there an alternative to it. I find bero and patton gateways, but they are of relatively different technology. Which one is easy to maintain for a non techie... What is the difference between a Songhoma and a Bero / Patton,. Can someone get me URLs to the same.
  2. misstake2012
    May 23, 2011
    40
    Discribe your problem and and e-mail to Sangoma support.
    It is good tech support that really helpful - support@sangoma.com
