3 Digit Extensions - using extensions below 100
Discussion in '3CX Phone System - General' started by TotallyVoIP, Aug 13, 2010.
  1. TotallyVoIP
    Jul 2, 2010
    77
    Is there any way to use the extensions below 100?
    Is it that hard to accept 001, or even 000 as an internal extension?
    When trying to create an extension starting with a "0" or less that 3 digits it just gives an error.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    3cx does not accept 0's in front of numbers, you must start from 10 for 2 digit 100 for 3 and 1000 for 4. Currently there is no way of changing this. You could request this feature in the request section of the forums.
