3 Minutes Drop
Discussion in '3CX Phone System - General' started by andrew.doades, Apr 4, 2011.
  1. andrew.doades
    Dec 10, 2010
    8
    We have 3CX V9 installed and we're getting our calls dropped after 3 minutes with the below scenario:
    This is under any of our phones.
    We have "Automatically Switch To Away Profile During Break" set with 09:00 -> 17:00 Monday to Friday.
    and "Include holidays" ticked.
    If we call into the 3CX system from outside, after 3 minutes dead, the call gets dropped from the 3CX side.
    Is anyone else experiencing this, or know if this is fixed in V10?
    Andrew
  2. andrew.doades
    Dec 10, 2010
    8
    It appears that if we set any extension to "Away" even manually we get the same issue, but the line is dropped after 30 seconds
    Andrew
  3. andrew.doades
    Dec 10, 2010
    8
    Setting the extension status to "Out of office" caused no problems
    and setting my status to "Away" during a call caused no problems
    I then called an extension directly whilst I was "Away" and we got cut off at 32 seconds
  4. inostar
    Jan 10, 2011
    5
    Hi there Andrew,
    I faced this problem a few months ago with my first 3CX installation.
    Enabling Keep-Alives resolved the issue for me.
    Settings ==> General ==> Global Options ==> "Enable Keep Alives"
    You may also need to enable "NAT Keep-Alives" within your phone's configuration.
    Shawn
  5. andrew.doades
    Dec 10, 2010
    8
    Thanks Shawn,
    I'll give this a go and update you with our results.
    Andrew
  6. andrew.doades
    Dec 10, 2010
    8
    HI Shawn,
    Unfortunately we've still got the same problem, after having set the Keep-Alive setting.
    Andrew
  7. BRIANTHEBEAR
    Apr 6, 2011
    Hi there, phone connection dropping all the time, our IT Dept have looked into this and still cant provide a solution. I am having to orderr a handset and ditch 3cx if I cant get this resolved.
    I see the comments about keep alive but cannot find where to do this?
    Any advice available before I throw it out ?
  8. andrew.doades
    Dec 10, 2010
    8
    We're currently doing some more tests also. We think its could be our voice mail/ring group setup.
    We'll be doing these tests this afternoon, so I'll update the post to let you know..
    Andrew
  9. andrew.doades
    Dec 10, 2010
    8
    Hi All,
    We've now identified the issue to be with our VOIP Provider!
    I would suggest you check with yours if you've got the same problem.
    After we switched to another VOIP provider on trial, everything is fine and we can make 15 minute + calls.
    Andrew
