3 Way Auth, Trunk behind other PBX
Discussion in '3CX Phone System - General' started by scholz, Jul 10, 2016.
  1. scholz
    Apr 14, 2015
    Hi @all,
    3 Way Authentication can't be used, because missing form for the ID
    [​IMG] v15
    [​IMG] v14
    Want to register the 3CX for testing behind a Mitel (need 3 Way Auth., or set the Number), but can't set:
    [​IMG]
    Can this new limit be changed?
    Thanks - Meik
    #1 scholz, Jul 10, 2016
  2. Aram
    Aram Support Team
    May 7, 2012
    116
    22
    @scholz
    3 Way Authentication can be used, we just rename the field name from 3 Way Authentication ID to 3 Way Authentication Password. The functionality is the same, so just put the existed 3 Way Authentication variable into the 3 Way Authentication password field.
    Yes, we have this new limitation and it can't be changed. You need to use the 4 digits (or more) in the Main Trunk number field.
