302 error on session transfer?
Discussion in '3CX Phone System - General' started by FallenTabris, Mar 14, 2012.
  1. FallenTabris
    Feb 24, 2012
    People dial in to the auto attendant and no matter what they press it just restarts them. Here is a block of numbers who have called us and had the problem.
    11:59:33.508|1044|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(bkerr445s1g3v045tnevnm55))/dr.aspx?dr=8000&to=8000&from=17349292329
    11:59:56.295|1044|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_17349292329_To_8000_Menu_8000_#0/32' session transferring to sip:8010@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    13:40:32.295|5800|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(htavzvbkiuxh5l55ox11u245))/dr.aspx?dr=8000&to=8000&from=17182613700
    13:40:52.142|5800|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_17182613700_To_8000_Menu_8000_#0/37' session transferring to sip:8001@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    14:49:43.829|4996|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(5l5y4x55her4mm553vtj4h45))/dr.aspx?dr=8000&to=8000&from=17322247132
    14:50:12.901|4996|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_17322247132_To_8000_Menu_8000_#0/39' session transferring to sip:8001@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    17:13:47.664|1992|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(j0bpn445yqamznnwf1bp4r55))/dr.aspx?dr=8000&to=8000&from=13102783311
    17:20:50.923|5744|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(5chjvmuflzmu4z45lgg5pa3x))/dr.aspx?dr=8000&to=8000&from=13102783311
    Any ideas?
  2. FallenTabris
    Feb 24, 2012
    Would anyone happen to know where else I could find an answer on this?
  3. FallenTabris
    Feb 24, 2012
  4. FallenTabris
    Feb 24, 2012
    I'm dyin squirtle
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    you might consider a support contract or something - this seems quite strange.
