3974: ringsounds and dialsounds
Discussion in 'Windows' started by Tugi2o, Jan 31, 2008.
  1. Tugi2o
    Feb 20, 2007
    61
    here's a litle improvement with RING & DIALINGTONES.
    I selected:
    Microphon device: HEADSET
    Ringing device: SIGMA TEL AUDIO (intern Soundcard) ==> this is the problem
    Playback device: HEADSET
    ringing sound = the sound which i can hear, when s.o. is calling me and my phone is ringing
    dialing sound = the sound which i can hear, when i call s.o. or type in the phone number of s.o.
    talking sound = voice, when s.o. is speaking with me
    So i think it would be better, if only the ringing sound would be played loudly by the pc-intern speakers, because my headset is not allways on my head.
    BUT the dialing sound should be played ONLY on my headset, so that ONLY i can hear it.
    I'm working in a big office and everybody can hear the dialingtones, when i call s.o. That's silly.
    I think this is an important improvement.
    Tugi2o
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello sir
    Valid point and a usefull feature. But don't the laptop speakers get automatically disabled as soon as you plug in a headset inthe mic/headphone jack?
    Or are these headsets bluetooth therefore selectable as an output option in the Multimedia Devices?
  3. Tugi2o
    Feb 20, 2007
    61
  4. Tugi2o
    Feb 20, 2007
    61
    Version 4132 : Problem solved - Thank you very much
  5. col
    col
    Jun 3, 2008
    I have a problem that I can't figure out. I will hear the ring tone if i dial any extension but I will not hear the greetings for any extension. Nor do I hear the greeting when I dial 999.
    I'm using my laptop which has the SigmaTel Audio device.
    Everything works fine from another computer with a different sound device.
    Any suggestions?
