3974: Transfer (intern)
Discussion in 'Windows' started by Tugi2o, Jan 31, 2008.
  1. Tugi2o
    Feb 20, 2007
    61
    there is an other Problem, when i transfer a conversation. This problem did exist also in the older version and also in the new version 3794 of the client software:
    Does this happen only @ me???
    How to provoke this error:
    61, 62 and 63 are intern client numbers.
    61 is calling & speaking to 63 (LINE1)
    63 is opening a new line (LINE2), 61 can hear the waiting music
    63 is calling & speaking to 62 (LINE2)
    63 presses TRANSFER and then LINE1=61, now normally 61 should talk to 62 and 63 should be away from the conversation, but what happens:
    62 can talk to 63, 61 is still hearing the waiting music, but the muic is hanging, only some tones can be heared.
    LINE1 is shown as "dead" on the client of 62. Only LINE2 is active.
    Here is my log:
    11:56:05.506 CallCtrl::eek:nLegConnected [CM503007]: Call(26): Device joined: sip:62@192.168.0.142:5070;rinstance=e75ce0448f64dc1a
    62 connected to 63
    11:56:05.506 CallCtrl::eek:nLegConnected [CM503007]: Call(26): Device joined: sip:63@192.168.0.172:5070;rinstance=c3050709571d840d
    63 connected to 62
    11:55:55.576 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(26): Calling: Ext:62@[Dev:sip:62@192.168.0.142:5070;rinstance=e75ce0448f64dc1a]
    62 is ringing
    11:55:55.529 CallCtrl::eek:nIncomingCall [CM503001]: Call(26): Incoming call from Ext.63 to [sip:62@192.168.0.7:5060]
    63 is calling 62, on LINE2
    11:55:51.064 CallCtrl::eek:nLegConnected [CM503007]: Call(25): Device joined: sip:63@192.168.0.172:5070;rinstance=c3050709571d840d
    63 connected with 61
    11:55:51.048 CallCtrl::eek:nLegConnected [CM503007]: Call(25): Device joined: sip:61@192.168.0.133:5070;rinstance=644ddd0aca55da2a
    61connected with 63
    11:55:49.908 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(25): Calling: Ext:63@[Dev:sip:63@192.168.0.172:5070;rinstance=c3050709571d840d]
    63 is ringing
    11:55:49.877 CallCtrl::eek:nIncomingCall [CM503001]: Call(25): Incoming call from Ext.61 to [sip:63@192.168.0.7:5060]
    61 is calling 63
    Please try...
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    it depends to what device or provider you are transferring. Please let us know...
