3COM OfficeConnect Firewall
Discussion in '3CX Phone System - General' started by juanjo, Jul 24, 2007.
  1. juanjo
    Jul 16, 2007
    I'm using 3COM OfficeConnect firewall and i am not surewhat happens with ports.
    If i open all documented ports there is no sound in both directions, but if i bypass the firewall al works.
    UDP 5060-5061, 9000-9007, 5004-5005, 3478, 5482
    I know problems with firewalls are common, but really that's all ?
    Thanks in advanced
  2. Fynskisb16
    Jul 18, 2007
    21
    Are you forwarding the open port to your 3cx server? If not you need to. I have all those ports open on my Cisco router and forwarding to my server and everything is working fine.
  3. Anonymous
    Anonymous Guest
    Almost.
    Sound uses the 10000 - 20000 ports. Try open these (UDP) and it should work.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Documentation says that you need to forward ports to/from host of 3CX PBX (in both direction, it means make "full cone NAT" for PBX ports)...
