3cx 10 sp5 simultanious call forwarding issue
Discussion in '3CX Phone System - General' started by netswork, Jan 31, 2012.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Im running 3cx 10 sp5 with cisco spa525 phones. Using a patton 4960 with a PRI for dialtone. I have them using 9. as a prefix to dial out. I have their mobile phones setup as 9xxxxxxx. When I set their phone to ring their mobile and desk at the same time, the desk phone only rings once, then the mobile starts ringing. It happens for every extension. I have never seen it do this before. The only modifications I have made are
    From the 3CX Management , click on the Settings node and then on the Advanced sub-node
    Click on the ‘Custom Parameters’ tab
    In the ‘Filter by Parameter Name’ type ‘allowuse’ (no quotes) and click on the ‘Search’ button
    One entry appear, with a value of ’0′. Change this to ’1′ (no quotes).
    Click on Apply followed by OK.
    This is so that the ring group members can take more than one call at a time. All extensions are set to access more than one call at a time.
