3cx 10 Unable to place calls
Discussion in '3CX Phone System - General' started by sgiddey, Jun 23, 2011.
  1. sgiddey
    Aug 26, 2009
    14
    Hi there
    Just installed V10 successfully ??? However I can place calls locally to extensions. I can receive calls from external numbers but cannot make external calls. Soft phones as well. I am using Grandstream GPX2000. Everything works except outgoing. I am using VOIPGO as a provider. I have checked just about everything... dialed 9 xxx xxx xxxx dialed xxx xxx xxxx am I missing something.. Any assistance would be greatly appreciated.
    This is the error message on the phone....
    404 NOT FOUND
    Wrong NUMBER or remote party not online.
    SPG
  2. sgiddey
    Aug 26, 2009
    14
    If I use 3cx Softphone.. just a destination not found..
    SPG
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    More information would be needed, is the provider registered? how do you have outbound rules setup? maybe even some logs would help us sort this out.
    Thanks,
    Nate
  4. sgiddey
    Aug 26, 2009
    14
    Hopefully this will be of some help
    SPG
    11:54:51.218 [CM503008]: Call(60): Call is terminated
    11:54:48.099 [CM503007]: Call(60): Device joined: sip:101@192.168.0.20:52271;rinstance=e7dc4ed7d0cac63e
    11:54:48.093 [CM503007]: Call(60): Device joined: sip:100@192.168.0.43:5060;transport=udp
    11:54:45.291 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.19548.0] PBX contact: [sip:101@192.168.0.29:5060]
    11:54:45.291 [CM503002]: Call(60): Alerting sip:101@192.168.0.20:52271;rinstance=e7dc4ed7d0cac63e
    11:54:45.131 [CM503025]: Call(60): Calling Ext:Ext.101@[Dev:sip:101@192.168.0.20:52271;rinstance=e7dc4ed7d0cac63e]
    11:54:45.097 [CM503004]: Call(60): Route 1: Ext:Ext.101@[Dev:sip:101@192.168.0.20:52271;rinstance=e7dc4ed7d0cac63e]
    11:54:45.095 [CM503010]: Making route(s) to <sip:101@192.168.0.29>
    11:54:45.090 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:54:45.080 [CM503001]: Call(60): Incoming call from Ext.100 to <sip:101@192.168.0.29>
    11:54:41.135 [CM503020]: Normal call termination. Reason: Not found
    11:54:41.134 [CM503016]: Call(59): Attempt to reach <sip:102@192.168.0.29> failed. Reason: Not Found
    11:54:41.134 [CM503014]: Call(59): No known route to target: <sip:102@192.168.0.29>
    11:54:41.132 [CM503010]: Making route(s) to <sip:102@192.168.0.29>
    11:54:41.129 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:54:41.121 [CM503001]: Call(59): Incoming call from Ext.100 to <sip:102@192.168.0.29>
    11:54:29.834 [CM503020]: Normal call termination. Reason: Not found
    11:54:29.834 [CM503016]: Call(58): Attempt to reach <sip:0@192.168.0.29> failed. Reason: Not Found
    11:54:29.833 [CM503014]: Call(58): No known route to target: <sip:0@192.168.0.29>
    11:54:29.832 [CM503010]: Making route(s) to <sip:0@192.168.0.29>
    11:54:29.829 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:54:29.820 [CM503001]: Call(58): Incoming call from Ext.100 to <sip:0@192.168.0.29>
    11:54:22.814 [CM503020]: Normal call termination. Reason: Not found
    11:54:22.814 [CM503016]: Call(57): Attempt to reach <sip:917803705197@192.168.0.29> failed. Reason: Not Found
    11:54:22.814 [CM503014]: Call(57): No known route to target: <sip:917803705197@192.168.0.29>
    11:54:22.812 [CM503010]: Making route(s) to <sip:917803705197@192.168.0.29>
    11:54:22.808 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:54:22.800 [CM503001]: Call(57): Incoming call from Ext.100 to <sip:917803705197@192.168.0.29>
    11:54:14.134 [CM503020]: Normal call termination. Reason: Not found
    11:54:14.134 [CM503016]: Call(56): Attempt to reach <sip:7803705197@192.168.0.29> failed. Reason: Not Found
    11:54:14.134 [CM503014]: Call(56): No known route to target: <sip:7803705197@192.168.0.29>
    11:54:14.132 [CM503010]: Making route(s) to <sip:7803705197@192.168.0.29>
    11:54:14.128 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:54:14.121 [CM503001]: Call(56): Incoming call from Ext.100 to <sip:7803705197@192.168.0.29>
    11:53:57.743 [CM503020]: Normal call termination. Reason: Not found
    11:53:57.743 [CM503016]: Call(55): Attempt to reach <sip:17803705197@192.168.0.29> failed. Reason: Not Found
    11:53:57.743 [CM503014]: Call(55): No known route to target: <sip:17803705197@192.168.0.29>
    11:53:57.741 [CM503010]: Making route(s) to <sip:17803705197@192.168.0.29>
    11:53:57.737 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:53:57.729 [CM503001]: Call(55): Incoming call from Ext.100 to <sip:17803705197@192.168.0.29>
    11:53:20.593 [CM503008]: Call(54): Call is terminated
    11:52:57.666 [CM503007]: Call(54): Device joined: sip:100@192.168.0.43:5060;transport=udp
    11:52:57.654 [CM503007]: Call(54): Device joined: sip:gid6133441408@66.49.255.51:5060
    11:52:56.323 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:52:56.318 [CM503002]: Call(54): Alerting sip:100@192.168.0.43:5060;transport=udp
    11:52:56.174 [CM503025]: Call(54): Calling Ext:Ext.100@[Dev:sip:100@192.168.0.43:5060;transport=udp]
    11:52:56.146 [CM503004]: Call(54): Route 1: Ext:Ext.100@[Dev:sip:100@192.168.0.43:5060;transport=udp]
    11:52:56.142 [CM503010]: Making route(s) to <sip:100@192.168.0.29:5060>
    11:52:56.138 [CM505003]: Provider:[Generic VoIP Provider -] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] PBX contact: [sip:gid6133441408@67.193.170.98:5060]
    11:52:56.135 [CM503001]: Call(54): Incoming call from 17803705197@(Ln.10000@Generic VoIP Provider -) to <sip:100@192.168.0.29:5060>
    11:52:56.065 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:100
    11:52:27.912 [CM503003]: Call(53): Call to sip:100@192.168.0.29 has failed; Cause: 487 Request Cancelled; from IP:192.168.0.43:5060
    11:52:27.791 [CM503008]: Call(53): Call is terminated
    11:52:21.592 Currently active calls - 1: [53]
    11:52:18.041 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:52:18.041 [CM503002]: Call(53): Alerting sip:100@192.168.0.43:5060;transport=udp
    11:52:17.888 [CM503025]: Call(53): Calling Ext:Ext.100@[Dev:sip:100@192.168.0.43:5060;transport=udp]
    11:52:17.872 [CM503004]: Call(53): Route 1: Ext:Ext.100@[Dev:sip:100@192.168.0.43:5060;transport=udp]
    11:52:17.870 [CM503010]: Making route(s) to <sip:100@192.168.0.29:5060>
    11:52:17.866 [CM505003]: Provider:[Generic VoIP Provider -] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] PBX contact: [sip:gid6133441408@67.193.170.98:5060]
    11:52:17.853 [CM503001]: Call(53): Incoming call from 17803705197@(Ln.10000@Generic VoIP Provider -) to <sip:100@192.168.0.29:5060>
    11:52:17.779 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:100
    11:50:58.304 [CM503020]: Normal call termination. Reason: Not found
    11:50:58.304 [CM503016]: Call(52): Attempt to reach <sip:7803705197@192.168.0.29> failed. Reason: Not Found
    11:50:58.303 [CM503014]: Call(52): No known route to target: <sip:7803705197@192.168.0.29>
    11:50:58.301 [CM503010]: Making route(s) to <sip:7803705197@192.168.0.29>
    11:50:58.294 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:100@192.168.0.29:5060]
    11:50:58.291 [CM503001]: Call(52): Incoming call from Ext.100 to <sip:7803705197@192.168.0.29>
  5. sgiddey
    Aug 26, 2009
    14
    Thanks for the reply.. figured it out.. had no outbound rules ,.... duh.. created a rule and bingo.. thanks
    SPG
  6. nbailey
    nbailey Member
    Jan 31, 2011
    359
    I was just going to say that, then I read your last post. Glad you got it working and enjoy!!
    Thanks,
    Nate
