3CX 11 new install, auto-provisioning polycom 501
Discussion in '3CX Phone System - General' started by npereira, Aug 7, 2012.
  1. npereira
    Jan 5, 2009
    22
    Hi all,
    searched the forum for this but was not able to resolve.
    I have 50% of my userbase using 501's and currently on a Asterisk. I'm testing 3CX.
    I looked at the sip_31x.cfg in the provision folder and it stated to take the sip.ld and copy it to the povision folder as well as rename it to sip_31x.ld which i did.
    I then factory reset my 501 and changed the settings to be http.
    My Linux dhcp server has :
    host test-501-extension {
    hardware ethernet 00:04:f2:1c:e6:d6;
    fixed-address 172.20.32.36;
    option tftp-server-name "http://172.20.32.32:5000/provisioning";
    yes the phone boots up, loads app = sip_31x.ld and at the point where it should load the config, it stops and says confid file error error is 0x20 then proceeds to reboot.
    Can anyone shed some light on this?
    Greatly appreciated.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    take a look at the following:
    http://www.3cx.com/sip-phones/polycom-provisioning.html
