3cx 11 sp3 weird api forwarding error
Discussion in '3CX Phone System - General' started by peradise, Jan 10, 2013.
  1. peradise
    Oct 5, 2012
    6
    Hi all,
    we have written a small app that communicates through the api.
    You pass an extension number and a mobile phone number. It then changes the mobile number of that extension using :
    ex.SetProperty("MOBILENUMBER", Mobile_Number, PropertyType.String, "The mobile number specified for extension")
    Nothing fancy. This worked perfectly with the previous versions of 3cx 11. But now something strange happens. If the forwarding rules of the extension is set to "Send call to my mobile number" then the mobile number of the extension is changed correctly. But for all forwarding rules the forwarding is set to "An external number or Skype ID" and the OLD mobile number is set in it's field.
    See the attached pdf file with screenshots.
    Regards,
    Per
