3CX 12.5 Calls Colliding\Merging
Discussion in '3CX Phone System - General' started by rwasiewicz, Jun 29, 2015.
  1. rwasiewicz
    Jun 29, 2015
    All,
    I am experiencing an odd issue with my 3CX (v12.5) phone system, it's seems as though active calls are being interrupted from another extension on the phone system.
    For example, users 1 and 2 could be talking to each other, and users 3 and 4 doing the same, and for no reason users 3 and 4 will merge into users 1 and 2's conversation.
    I have searched through the logs, and couldn't find anything out of the ordinary. The issue even persists after a reboot and happens randomly to random users.
    Any help would be greatly appreciated.
    Rob
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi Rob,
    Kindly open a support ticket through your reseller so that we can investigate this further.
