3CX 12.5 - is it compatible with Windows 10 64 bit?
Discussion in '3CX Phone System - General' started by fryzb, Jan 26, 2018.
  1. fryzb
    Jan 26, 2018
    Hi Folks,
    Just wonder did you install 3cx 12.5 on Windows 10 64 bit?
    Regards,
    Fryzb
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Please note: 15.5 runs fine on Windows 10/64. Why would you run such an old version?
  3. leejor
    11,127
    330
    12.5 did require a 64 bit processor. Other than some time, you don't have much to loose in attempting an install. My guess would be that it will work, but can't confirm personally. Unless you already have a licence for 12.5 and have some reason not to upgrade, I would suggest that you do
  4. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    30
    I would choose to run it off the inbuilt web server not IIS as you will be limited in the number of connections IIS on a desktop can handle (i believe its 10 max).
    Ultimately I would upgrade to 15.5 but I don't know your circumstances.
  5. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,255
    203
    Has to to be Pro / Enterprise version of Windows 10 64bit
