3CX 12 with Snom 715 - Intercom Auto Answer on Speaker?
Discussion in '3CX Phone System - General' started by millennium2, Jan 30, 2015.
  1. millennium2
    Apr 8, 2011
    57
    I am having trouble with getting a Snom 715 to auto answer on speaker when someone intercoms it. No matter what settings I choose on the Snom 715, I have to pick up the handset in order to answer the intercom.
    Is there a solution to this?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    You say you have tried everything - but we do not know what that means.... So any recommendation we make you may have tried.
    Have you tried the 'IDLE' setting which should allow Auto Answer of intercom if no cal is active (phone is idle) ?
    Code:
    <answer_after_policy perm="">idle</answer_after_policy>
    <auto_connect_type perm="">auto_connect_type_handsfree</auto_connect_type>
    <auto_connect_indication perm="">on</auto_connect_indication>
  3. millennium2
    Apr 8, 2011
    57
    Hi Craig,
    I currently had the Intercom Policy set as "Always". I just set it to "Only in Idle" remotely. Will let you know how I make out as soon as I get on site.
    Many thanks for your assistance!
      File size:
      153.4 KB
      251
