3CX 15.1 Pro - Queue Callback broken
Discussion in '3CX Phone System - General' started by pact, Aug 11, 2016.
  1. pact
    pact New Member
    Dec 16, 2009
    205
    37
    Just testing the callback option after timeout.
    In V14 after timeout the system announces 'You have requested a call back on the following number: ##########, Press 0 to change etc etc'
    In V15 after timeout the system announces the number and nothing else, so we just get '##########' and silence...
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    Just tested this but it works on mine. Did you restore a backup from a previous versions on which you had custom promptsets? Worth noting that I used the US English Promptset.
  3. pact
    pact New Member
    Dec 16, 2009
    205
    37
    Interesting question on the Prompt Set.
    I've just had a look, yes we are using a custom promptset which came over from V14.
    The callback entries are completely missing from our promptset, where they are present in the default.
    Why would have V15 stripped the callback prompts? We have never changed those entries..
    And how do we restore them?
  4. NickD_3CX
    Jun 2, 2014
    1,367
    83
    If you still have the V14 backup zip file, in it the .wav files should still be there.
    Once you retrieve the .wav files from there, from the V15 Management Console -> Settings -> System Prompts, select your custom promptset and for the "Prompt IDs" that are missing, re-upload the corresponding .wav file.
