3CX 15.5 outgoing call problem with Beronet
PaulusAgung
I'm newbie with 3CX and Beronet.
I'm trying 3CX 15.5 free version. I use Beronet BF64004E1box as media gateway to connect to E1.
The problem now is when I try outgoing call to number starting with 0 eg. 081234567 the call is failed. But when I try outgoing call to number not starting with 0 eg 29271222 the call success.
Dialplan debug in Beronet says "Unallocated number". I notice "0" is missing in the dad.
CDR,18,SIP:172.30.152.20,ISDN:1:1,"29270111" <sip:[email protected]>,"" <sip:[email protected]>,10001,08119693111,18/02/17-01:22:38,18/02/17-01:22:38,-,-,ISDN,EVENT_DISCONNECT:1,-,-
S Unallocated number|REQUEST: from="29270111" [email protected], to= "" [email protected]
I DISCONNECT|INDICATION: port=1, channel=1, dad=8119693111, oad=, cause=1 (Unallocated number)
I SETUP|REQUEST: port=1, channel=1, dad=8119693111, oad=
D INCOMING: FROM_ID=a:3CX, TO_ID=g:ISDN-Extern-Li0, src:10001 dest:08119693111 -- OUTGOING new_src:10001 new_dest:08119693111
S INVITE|INDICATION: from="29270111" [email protected], [email protected]
Please help me to solve this problem.
I bet on ISDN-Extern-Li0 configuration you have oad (Caller ID) configured as new_source_auto. Edit and set oad (Caller ID) with value new_source and set Country Code, City Code are Local are code with null value on same ISDN-Extern-Li0 configuration. Then try again.
Hi Manfer,
You were almost right.
The problem is not oad, but dad.
I found after change dad (Callee ID) in ISDN-Extern-Li0 from new_destination_auto to new_destination then I can call number starting with 0.
Thanks!!
Reactions: manfer
Getting Started - Admin
sd24mi
Get 3CX - Absolutely Free!
3CX
