3CX 15.5 sp2 recording bug
Discussion in '3CX Phone System - General' started by THCO, Nov 16, 2017.
  1. THCO
    May 16, 2017
    55
    11
    I noticed that when I go to the recordings screen I can not sort the recording using any of the top menu. I try to sort by date and nothing happens. If I try to use any of the other buttons (caller id, display name, source, destination, filename) and they do not work either.
    I have tried multiple browsers, cleared the cache and used different devices. Anyone else having this issue who records calls?
    jimbo59 and JWillScott like this.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    I can reproduce the issue too.
    jimbo59 likes this.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    We will check - thanks for reporting guys..
  4. JWillScott
    Nov 18, 2017
    10
    I'm experiencing the same problem in the log sorting, but I'm also experiencing a problem with not all calls being recorded as they have been in the past before the upgrade.
    jimbo59 likes this.
  5. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Me too. Client will be quite upset.
    I don't see recordings since the upgrade 2 days ago.
    Client requires recording all calls.
    #5 jimbo59, Nov 18, 2017
    JWillScott likes this.
  6. THCO
    May 16, 2017
    55
    11
    I thought the same to as no calls were being recorded but if you use the search bar at the top of the page and input the date (dd/mm/yyyy) then the calls will come up. You can also input extension number and look to the left of the list that comes up for the date you want.
    This is how I found all my recordings after the sp2 upgrade.
    jimbo59 likes this.
  7. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Great. I see the recordings. Should be simple fix for them.
    THCO likes this.
  8. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    We have reproduced the issue and fixed it already - will be available in the next update. Thank's all for reporting..
  9. THCO
    May 16, 2017
    55
    11
    When is the next update?
  10. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Depends on the bug reports we get (This one is a perfect example.) Bear with us a little while longer. Maybe if the fix is in one place I can post a patch with some simple instructions on how to fix it. I would need to check further..
    We also have to push other features - We are really trying to regroup right now after last weeks release. So exact ETA is not yet decided but I will touch base to you guys on this one.
  11. THCO
    May 16, 2017
    55
    11
    Thank You Nicky for an awsome product and for these forums to have direct access to the 3CX crew.
  12. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    You gonna give the ability to replace the Queue music? My clients hate it.
    They use ring groups instead.
  13. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
    You can already do this, Music on Hold settings within Queue Settings.
  14. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Music on hold is not a ring. By ring music I mean the dramatic music that is supposed to be a ring. My clients don't like it and many don't.
    accentlogic likes this.
  15. Saqqara
    Mar 12, 2014
    877
    135
    Try Changing the way file to usprogresstone.wav , just done the same for a client
  16. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    We are not communicating. Music on hold works fine. The ringing of the queue is what sounds like a horror movie.
  17. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    We have resorted to a custom template to resolve the default Queue ringer. We change that and the flashing 3CX logo. Other than those we find little left that can't be done in the new Provisioning tab options. (I just wish we could set system-wide defaults so they start how we want them...)
    Find the below setting:
    distinctive_ring_tones.alert_info.6.ringer = 6
    And replace it with:
    distinctive_ring_tones.alert_info.6.ringer = 3
    (you can replace the "3" above with any of the ringer numbers that you want to use.)
  18. haldop
    Aug 29, 2017
    6
    Hello.
    When this new upgrade with Recordings screen bug fix will be realese?
    Using this now is really upset. Managing is drama.
    Regards
    jimbo59 and sip.bg like this.
  19. accentlogic
    Nov 14, 2013
    161
    66
    The last update resolved the issue for us. If you are still not seeing the recordings correctly a support ticket is probably in order so they can look your situation over.
  20. JWillScott
    Nov 18, 2017
    10
    @haldop
    It still doesn't work for us either...
    haldop likes this.
