3CX 15.5 Support for Portech MV374n & Patton Smartnode 4520
Discussion in 'Windows' started by John Philip Navarro, Jul 17, 2017.
  1. John Philip Navarro
    Apr 21, 2017
    Good Day,
    May I ask if the newest version of 3CX, ver 15.5, supports Portech MV374n & Patton Smartnode 4520?
    If it is not supported anymore, will I still be able to use my devices by configuring it to standard SIP?
    Hope to hear from you soon.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    From my own experience I can tell the Portech MV370 and MV372 work well with v15.5
    I do not have any experience with the Patton Smartnode.
