3CX 7.0: Server Error Win 2003 IIS Installation
Discussion in '3CX Phone System - General' started by honk, Feb 19, 2009.
  1. honk
    Feb 19, 2009
    Dear colleagues,
    having installed 3CX 7.0 on a Windows Server 2003 with IIS 6 I get the following Server error when trying to access the management page:
    Server Error in '/management' Application.
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: Could not load type '_3cxIvr.VxmlHttpHandler'.
    Source Error:
    Line 12: -->
    Line 13: <httpHandlers>
    Line 14: <add verb="GET" path="*.vxml" type="_3cxIvr.VxmlHttpHandler"/>
    Line 15: </httpHandlers>
    Line 16: <globalization/>
    Source File: C:\Program Files\3CX PhoneSystem\Data\Http\Interface\ivr\web.config Line: 14
    Can you please support me in fixing this? Any ideas?
    Thanks a lot
    Markus
  2. Addy
    Mar 14, 2009
    Did you have any joy with this error. I am getting it now :-(
    Pleaseeeeee
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Check that all the 3CX virtual directories are running under the 3CX application pool, not the "Default Application Pool"
  4. callsanjeevat
    Mar 15, 2009
    Step 1 - Go to IIS. Right click on ivr(the main Application of 3cx) and click on Open. This will open the Physical Folder of teh application. Navigate to BIN directory. You will see the 3cxIvr.dll
    Step 2 - Right Click on Virtual Directory Management and click open. This will open the Physical Folder of the Virtual Directory.Navigate to Bin Directory.Copy the 3cxIvr.dll from mStep 1 to this directory.
    Step 3 - Right Click on Virtual Directory MyPhone and click open. This will open the Physical Folder of the Virtual Directory.Navigate to Bin Directory.Copy the 3cxIvr.dll from mStep 1 to this directory.
    Now The error will not show.
    Regards and Cheers
