3cx 7 + patton 4554
Discussion in '3CX Phone System - General' started by radix, Jan 14, 2009.
  1. radix
    Feb 5, 2008
    23
    I have an Patton 4554 R5.2 and an 3cx 7.0.4744.
    I have an voip (sipgate) configured and working good.
    Now I try to add the 4554 (R5.x) to the pstn and during the wizard at the "Create ports" step I get an exception and can't go further.
    The Exception says:
    An exception occured CreateLines Error: External Line.
    The values are the default one( see pictures). The sipgate virtual extension is 10000. The internal extensions are 2 digit.
    [​IMG]
    Anyone have an ideea what this could be?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    170
    Hi we will check this out. Can you send me a backup of your system (without prompts or recordings to keep it as small and compact as possible) so I can have a look at it?
    Send it directly to nb@3cx.com
    thanks
