Solved 3CX account lost
Discussion in 'iOS' started by spring, Dec 6, 2016.
  1. spring
    Nov 20, 2014
    53
    Any one get same as me that often lost 3CX account and need to send welcome mail again?
    3CX client for 3CXPhoneSystem 14/15 verson 15.1.1.22
    iPhone ios 9.0.2.
    Please help
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    Please check how much space is available on your iPhone - it seems that if there's less than 1GB, iOS (since 9.x) cleans app's user data (where the profiles are stored).
    We fixed this issue in the latest 3CX client 15.2.2, but it requires minimum iOS 10.x.
    spring likes this.
  3. spring
    Nov 20, 2014
    53
    Ok Vali, thanks you for your information
