3CX Amazon EC2 Instance
Discussion in '3CX Phone System - General' started by robert.smallridge, Mar 23, 2011.
  1. robert.smallridge
    Mar 23, 2011
    I want to be able to run 3CX on an Amazon Instance,
    I have set up an Windows server 2008 Instance, with IIS and 3cx Installed. I have also assigned an Elastic IP to the instance so that it has a public address I can access. I can access the web Admin, But I cannot get any phones to connect to the server, I have enabled ports 5481, 5060-5080 and 5471 on the server, but still no luck.
    Sip phones logs say the SIP registration has been sent but 3CX logs show no sip registration requests.
    Has anyone been able to successfully set up a 3CX installation on an Amazon EC2? Or can anyone help in figuring out the problem?
  2. komputer
    Aug 3, 2009
    5
    Have you tried the 3CX Firewall Checker to make sure all ports are working properly?
    http://www.3cx.com/blog/docs/firewall-checker/
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Rob, can you also enable 9000-9049
    i did run the firewall checker and all passed ok
    I was able to connect our Snom phones and our Softphone and they registered ok.
    i will have a look in to this again, been a busy day so been doing it when not so busy.
  4. dannybrook
    Feb 24, 2010
    43
    when you say you enabled those ports, do you mean on the ec2 firewall? i had no problem connecting a polycom and the 3cx softphone.
    ec2 is pretty expensive though to run a windows instance 24/7. you can get a hosted vps for less per month, though it is considerably less dynamic.
  5. davidbenwell
    Apr 27, 2010
    704
    We have fully set this up for Rob and all is working ok, We where able to connect two IP Phones and make and receive calls.
  6. dannybrook
    Feb 24, 2010
    43
    just curious why you chose EC2 when you can get a windows VPS for less per month?
  7. mbaitelli
    Mar 2, 2012
    Hi, I have the same issue. I cannot register extesions when using EC2. Can you post the solution so I can replicte on my instance?
    Thank you
  8. 3cxonec2
    Jul 1, 2013
    How did you get 3CX to work on Amazon EC2? I am also having the same problem as the original post, I cannot register my sip phones to the 3CX on the Amazon EC2. Please post solution. Thanks
