3cx, analog devices and patton
Discussion in '3CX Phone System - General' started by jlizzotte, May 30, 2015.
  1. jlizzotte
    May 30, 2015
    Guys, I have a Patton M-ATA, T38, sip trunk that supports it, and every time I send a fax, it comes up with error messages. Is there any tips on how to make it work properly? because the How To basically just has everything default for options, other then the registration info, and that is not working, at all. Thanks!
    11,285
    360
    The difference between working and not, can sometimes come down to the particular fax machine. Haven't seen a lot dealing with fax and that ATA. The Patton forums might be a good place for any additional information on settings if you are think you may have missed something enabling t.38.
