Solved 3CX and Active Directory integration / sync users problem
route
Hello
I have 3CX Windows server which is in a domain group. When i try to import users using AD import button its not doing anything.. no import, no errors... how can i debug the problem?
i can properly query AD using a small windows tool at 3CX server..
any help?
Dear route,
This procedure does not import the whole database. It does import only the information of the current call asynchronously . When a call comes in, the pbx search the synchronized LDAP directory and use the contact information from there. But you will not see the information on the phone at the first call as the search is taking place. You will see the information on the second call when the contact information is imported and so on.
is there any updated manual? or can you please tell me steps to to?
When i press search why nothing happening ?
how can i debug this problem? nothing happens when we click search...
Hi route,
Please Check this document http://www.3cx.com/blog/docs/import-active-directory/.
I will suggest you to change Authentication type to Negotiate as from the screenshot i can see that you use anonymous.
If this doesn't work for you enable logging to verbose and check Management Console and System Service Log from
%programdata%\3CX\Instance1\Data\Logs
2016/12/10 13:35:12.716|2688|0018|Dbg|Connection id "0HL0VF543KJND" started.
2016/12/10 13:35:12.716|2688|0055|Trc|Request starting HTTP/1.0 GET http://192.168.70.200/api/ldap/getOptions
2016/12/10 13:35:12.717|2688|0055|Dbg|The request path /api/ldap/getOptions does not match a supported file type
2016/12/10 13:35:12.717|2688|0055|Dbg|The request path does not match the path filter
2016/12/10 13:35:12.717|2688|0055|Trc|Performing unprotect operation to key {7367db4a-42ba-4f3f-b343-8e92e3cb05e5} with purposes ('C:\ProgramData\3CX\Instance1\Data\Http\webroot', 'Microsoft.AspNetCore.Authentication.Cookies.CookieAuthenticationMiddleware', 'Cookies', 'v2').
2016/12/10 13:35:12.717|2688|0055|Trc|HttpContext.User merged via AutomaticAuthentication from authenticationScheme: Cookies.
2016/12/10 13:35:12.717|2688|0055|Dbg|Request successfully matched the route with name '' and template 'api/Ldap/getOptions'.
2016/12/10 13:35:12.717|2688|0055|Dbg|Executing action ManagementConsoleJS.Controllers.LdapController.GetOptions (3CXManagementConsole)
2016/12/10 13:35:12.717|2688|0055|Trc|Authorization was successful for user: Administrator.
2016/12/10 13:35:12.717|2688|0055|Trc|Executing action method ManagementConsoleJS.Controllers.LdapController.GetOptions (3CXManagementConsole) with arguments () - ModelState is Valid
2016/12/10 13:35:12.717|2688|0055|Dbg|Executed action method ManagementConsoleJS.Controllers.LdapController.GetOptions (3CXManagementConsole), returned result Microsoft.AspNetCore.Mvc.ObjectResult.
2016/12/10 13:35:12.717|2688|0055|Dbg|No information found on request to perform content negotiation.
2016/12/10 13:35:12.718|2688|0055|Dbg|Selected output formatter 'Microsoft.AspNetCore.Mvc.Formatters.JsonOutputFormatter' and content type 'application/json' to write the response.
2016/12/10 13:35:12.718|2688|0055|Trc|Executing ObjectResult, writing value Microsoft.AspNetCore.Mvc.ControllerContext.
2016/12/10 13:35:12.718|2688|0055|Trc|Executed action ManagementConsoleJS.Controllers.LdapController.GetOptions (3CXManagementConsole) in 0.6822ms
2016/12/10 13:35:12.718|2688|0055|Trc|Request finished in 1.4911ms 200 application/json; charset=utf-8
2016/12/10 13:35:12.718|2688|0055|Dbg|Connection id "0HL0VF543KJND" disconnecting.
2016/12/10 13:35:12.718|2688|0018|Dbg|Connection id "0HL0VF543KJND" sending FIN.
2016/12/10 13:35:12.718|2688|0018|Dbg|Connection id "0HL0VF543KJND" sent FIN with status "0".
2016/12/10 13:35:12.718|2688|0018|Dbg|Connection id "0HL0VF543KJND" stopped.
2016/12/10 13:35:37.543|2688|0009|Trc|Incoming Event: REGISTRATION.51->Updated
2016/12/10 13:35:37.543|2688|0009|Dbg|Enqueue Updated.REGISTRATION.51
2016/12/10 13:35:37.543|2688|0009|Trc|EventConnector.Root_Updated(REGISTRATION 700)
2016/12/10 13:35:37.543|2688|0009|Trc|EventConnector.EventRoutePoint.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.543|2688|0009|Trc|PipelineTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.543|2688|0009|Trc|InsertonFixTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.543|2688|0009|Trc|ExtensionCeationTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.543|2688|0009|Trc|ConnectionRegistrationTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.544|2688|0009|Dbg|'Updated REGISTRATION:700' skipped
2016/12/10 13:35:37.544|2688|0009|Trc|PipelineTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.544|2688|0009|Trc|InsertonFixTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.544|2688|0009|Trc|ExtensionCeationTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.544|2688|0009|Trc|ConnectionRegistrationTransformer.OnEvent(Updated REGISTRATION:700)
2016/12/10 13:35:37.545|2688|0008|Dbg|Dequeue Updated.REGISTRATION.51
2016/12/10 13:35:37.545|2688|0008|Dbg|GetGroupsChange enters
2016/12/10 13:35:37.545|2688|0008|Dbg|GetGroupsChange ends
2016/12/10 13:35:37.545|2688|0008|Dbg|Processed REGISTRATION.51
Hi route ,
Do you use firefox ? if yes please try from chrome and let us know if that was the issue
Reactions: admin
i waste 1 week, its done with chrome!
Get 3CX - Absolutely Free!
3CX
