3cx and Asterisk integration
Discussion in '3CX Phone System - General' started by falves11, Apr 19, 2015.
  1. falves11
    Apr 19, 2015
    I was trying too add my own Asterisk as a VOIP provider, and I could not find a way to add non-Listed VOIP provider.
    Also, another VOIP provider does not support registration, the authentication is only via Public IP. How do I add it to the list?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Use the listing labeled as generic. You will see this in the country listing. Once selected, you can pretty much tailor to your needs.
  3. jasit
    jasit New Member
    Feb 12, 2013
    171
    I created a post on how to bridge calls between the two,
    I just got it working this morning. I was curious about how it worked too.
    Here are the steps I followed
    On the 3cx Server
    1) Create the Master Direct-UDP Bridge
    Virtual extension number 10002
    Authpassword 55555
    Take note of the password
    Check both allow outbound and inbound calls
    support re-invite yes
    support replaces yes
    pbx Delivers Audio
    add G.711 U
    add G.711 A
    2) Create a outbound route matching the extensions on the Freepbx server
    On the Freepbx server
    1) Create a Trunk
    Trunk Name 3CXserver
    Peer Details area
    username=10002
    type=peer&friend
    secret=55555
    nat=auto
    insecure=very
    host=192.168.0.90
    fromuser=10002
    fromdomain=192.168.0.90
    dtmfmode=auto
    disallow=all
    context=from-internal
    allow=ulaw
    Register String
    10002:55555:10002@192.168.0.90:5060/10002
    2) Create an outbound route
    Intra-Company Checked
    Dial pattern to match the extensions on 3CX
    Trunk Sequence select 3CXserver
    jasit
    Expert
    Expert
  4. 3cxBora
    Jun 17, 2015
    35
    Hi, does any know if the 3cx v14 can bridge with Asterisk PBX.
    I want to get instructions how to configure this and if it will allow extension to extension dialing?
