tone disconnect is enabled
here is my config : can you compare it with yours? or send me yours to compare to
;** Ini File **
;Board: MP-118 FXO
;Serial Number: 943880
;Slot Number: 1
;Software Version: 5.20A.024.002
;DSP Software Version: 204IM => 520.12
;Board IP Address: 172.16.1.56
;Board Subnet Mask: 255.255.255.0
;Board Default Gateway: 172.16.1.1
;Ram size: 32M Flash size: 8M
;Num DSPs: 2 Num DSP channels: 8
;Profile: NONE
[SYSTEM Params]
DNSPriServerIP = 0.0.0.0
DNSSecServerIP = 0.0.0.0
SyslogServerIP = 172.16.1.4
EnableSyslog = 1
VXMLFIleName = ''
VoiceMenuPassword = 'disable'
ActivityListToLog = 'dr'
[BSP Params]
PCMLawSelect = 3
EnableLANWatchdog = 0
EnableMultipleIPs = 0
NETWORKSERVICECLASSDIFFSERV = 48
PREMIUMSERVICECLASSMEDIADIFFSERV = 46
PREMIUMSERVICECLASSCONTROLDIFFSERV = 40
GOLDSERVICECLASSDIFFSERV = 26
BRONZESERVICECLASSDIFFSERV = 10
RoutingTableHopsCountColumn = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
[ATM Params]
[Analog Params]
MinFlashHookTime = 100
FXSLoopCharacteristicsFilename = 'MP11x-02-1-FXS_16KHZ.dat'
FarEndDisconnectType = 15
ANALOGPORTINFO = ''
[ControlProtocols Params]
AdminStateLockControl = 0
[MGCP Params]
[MEGACO Params]
EP_Num_0 = 0
EP_Num_1 = 1
EP_Num_2 = 0
EP_Num_3 = 0
EP_Num_4 = 0
[PSTN Params]
[SS7 Params]
[Voice Engine Params]
BrokenConnectionEventTimeout = 100
DJBufMinDelay = 70
RFC2833PayloadType = 101
ECDCRemoval = 1
FarEndDisconnectSilenceMethod = 1
FarEndDisconnectSilencePeriod = 15
CallProgressTonesFilename = 'usa_tones_12.dat'
[WEB Params]
LogoWidth = '339'
[SIP Params]
ENABLECALLERID = 1
MAXDIGITS = 49
DISCONNECTONBUSYTONE = 1
ISPROXYUSED = 1
ISREGISTERNEEDED = 1
ISWAITFORDIALTONE = 0
ISTWOSTAGEDIAL = 0
ROUTEMODEIP2TEL = 0
FXOBETWEENRINGTIME = 8
ENABLECURRENTDISCONNECT = 1
ENABLEREVERSALPOLARITY = 1
SECURECALLSFROMIP = 0
ENABLEBUSYOUT = 0
CDRREPORTLEVEL = 0
MAXACTIVECALLS = 8
CHANNELSELECTMODE = 2
GWDEBUGLEVEL = 5
PROXYNAME = '172.16.1.4'
SIPGATEWAYNAME = '172.16.1.56'
STATICNATIP = 0.0.0.0
ENABLESILENCEDISCONNECT = 1
ENABLEVOICEDETECTION = 1
DEFAULTRELEASECAUSE = 3
PROGRESSINDICATOR2IP = -1
FILTERCALLS2IP = 0
PRACKMODE = 0
GWAPPDELAYTIME = 7
ENABLEDIDWINK = 0
DISCONNECTONBROKENCONNECTION = 1
ENABLEDIGITDELIVERY = 0
CDRSYSLOGSERVERIP = 0.0.0.0
PSTNALERTTIMEOUT = 180
ENABLEDIGITDELIVERY2IP = 0
SENDMETERING2IP = 0
MAXCALLDURATION = 0
RINGSBEFORECALLERID = 1
ENABLEUSERINFOUSAGE = 0
GUARDTIMEBETWEENCALLS = 1
DISCONNECTONDIALTONE = 1
SetDefaultOnIniFileProcess = 0
[VXML Params]
[IPsec Params]
[Audio Staging Params]
; *** TABLE DspTemplates ***
; This table contains hidden elements and will not be exposed.
; This table exists on board and will be saved during restarts
; *** TABLE CoderName ***
[ CoderName ]
FORMAT CoderName_Index = CoderName_Type, CoderName_PacketInterval, CoderName_rate, CoderName_PayloadType, CoderName_Sce;
CoderName 0 = g711Ulaw64k, 20, 0, 0, 0;
CoderName 1 = g711Alaw64k, 20, 0, 8, 0;
[ \CoderName ]
; *** TABLE TrunkGroup ***
[ TrunkGroup ]
; ** NOTE: Changes were made to active configuration.
; ** The data below is different from current values.
FORMAT TrunkGroup_Index = TrunkGroup_TrunkGroupNum, TrunkGroup_FirstTrunkId, TrunkGroup_FirstBChannel, TrunkGroup_LastBChannel, TrunkGroup_FirstPhoneNumber, TrunkGroup_ProfileId, TrunkGroup_LastTrunkId, TrunkGroup_Module;
TrunkGroup 0 = 1, 255, 1, 1, 10101, 0, 255, 255;
TrunkGroup 1 = 1, 255, 2, 2, 10102, 0, 255, 255;
TrunkGroup 2 = 1, 255, 3, 3, 10103, 0, 255, 255;
TrunkGroup 3 = 1, 255, 4, 4, 10104, 0, 255, 255;
[ \TrunkGroup ]
; *** TABLE PstnPrefix ***
[ PstnPrefix ]
FORMAT PstnPrefix_Index = PstnPrefix_DestPrefix, PstnPrefix_TrunkGroupId, PstnPrefix_SourcePrefix, PstnPrefix_SourceAddress, PstnPrefix_ProfileId;
PstnPrefix 0 = *, 1, *, *, 0;
[ \PstnPrefix ]
; *** TABLE ProxyIp ***
[ ProxyIp ]
FORMAT ProxyIp_Index = ProxyIp_IpAddress;
ProxyIp 0 = 172.16.1.4;
[ \ProxyIp ]
; *** TABLE T
tmfOption ***
[ T
tmfOption ]
FORMAT T
tmfOption_Index = T
tmfOption_Type;
T
tmfOption 0 = 4;
[ \T
tmfOption ]
; *** TABLE TrunkGroupSettings ***
[ TrunkGroupSettings ]
FORMAT TrunkGroupSettings_Index = TrunkGroupSettings_TrunkGroupId, TrunkGroupSettings_ChannelSelectMode, TrunkGroupSettings_RegistrationMode, TrunkGroupSettings_GatewayName;
TrunkGroupSettings 0 = 1, 7, 0, ;
[ \TrunkGroupSettings ]
; *** TABLE TelProfile ***
[ TelProfile ]
FORMAT TelProfile_Index = TelProfile_ProfileName, TelProfile_TelPreference, TelProfile_CodersGroupID, TelProfile_IsFaxUsed, TelProfile_JitterBufMinDelay, TelProfile_JitterBufOptFactor, TelProfile_IPDiffServ, TelProfile_SigIPDiffServ, TelProfile_DtmfVolume, TelProfile_InputGain, TelProfile_VoiceVolume, TelProfile_EnableReversePolarity, TelProfile_EnableCurrentDisconnect, TelProfile_EnableDigitDelivery, TelProfile_EnableEC, TelProfile_MWIAnalog, TelProfile_MWIDisplay, TelProfile_FlashHookPeriod, TelProfile_EnableEarlyMedia, TelProfile_ProgressIndicator2IP, TelProfile_TimeForReorderTone;
TelProfile 1 = "Default Tel Profile", 1, 0, 1, 70, 10, 46, 40, -11, 0, 0, 0, 1, 0, 1, 0, 0, 400, 1, 0, 255;
[ \TelProfile ]
; *** TABLE EnableCallerId ***
[ EnableCallerId ]
FORMAT EnableCallerId_Index = EnableCallerId_IsEnabled;
EnableCallerId 0 = 1;
EnableCallerId 1 = 1;
EnableCallerId 2 = 1;
EnableCallerId 3 = 1;
EnableCallerId 4 = 1;
EnableCallerId 5 = 1;
EnableCallerId 6 = 1;
EnableCallerId 7 = 1;
[ \EnableCallerId ]
; *** TABLE CallerDisplayInfo ***
[ CallerDisplayInfo ]
FORMAT CallerDisplayInfo_Index = CallerDisplayInfo_DisplayString, CallerDisplayInfo_IsCidRestricted;
CallerDisplayInfo 0 = 2087355159, 0;
CallerDisplayInfo 1 = 2087358212, 0;
CallerDisplayInfo 2 = 2087353924, 0;
CallerDisplayInfo 3 = 2087358622, 0;
CallerDisplayInfo 4 = , 1;
CallerDisplayInfo 5 = , 1;
CallerDisplayInfo 6 = , 1;
CallerDisplayInfo 7 = , 1;
[ \CallerDisplayInfo ]
; *** TABLE TargetOfChannel ***
[ TargetOfChannel ]
FORMAT TargetOfChannel_Index = TargetOfChannel_Destination, TargetOfChannel_Type;
TargetOfChannel 0 = 10101, 1;
TargetOfChannel 1 = 10102, 1;
TargetOfChannel 2 = 10103, 1;
TargetOfChannel 3 = 10104, 1;
TargetOfChannel 4 = 10105, 0;
TargetOfChannel 5 = 10106, 0;
TargetOfChannel 6 = 10107, 0;
TargetOfChannel 7 = 10108, 0;
[ \TargetOfChannel ]
; *** TABLE Authentication ***
[ Authentication ]
FORMAT Authentication_Index = Authentication_UserId, Authentication_UserPassword;
Authentication 0 = 10101, 10101;
Authentication 1 = 10102, 10102;
Authentication 2 = 10103, 10103;
Authentication 3 = 10104, 10104;
[ \Authentication ]
