3CX and Bandwidth.com
Discussion in '3CX Phone System - General' started by php master, Oct 18, 2017.
  1. php master
    Oct 18, 2017
    Hi Guys,
    I need a hep to set up a Sip Trunk with Bandwidth.com, i am looking to have a minimal configuration for just one person (Myself).
    [​IMG]
    [​IMG]
    Thank you
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Perhaps talk to an Expert on their site? It seems that static IP is required!
    SIP endpoints
    Code:
    user1234@xyz-corp-testing.bwapp.bwsip.io
    #2 Sopock, Oct 18, 2017
  3. StefanW
    Jun 2, 2009
    1,218
    89
  4. php master
    Oct 18, 2017
    I am a beginner and still not sure how i should call the API from the 3CX itself.
    I checked this page before and it doesn't have any helpful information it's just some VOIP providers.
    I appreciate your time guys
  5. StefanW
    Jun 2, 2009
    1,218
    89
    From 3CX there is no API to BW it self, the trunk needs to be set at BW end and the same config needs then to be placed into 3CX.
    If you want to go "automated" you could write a tool which uses on our end the "Call Control API" and parse the data from the API to us to create a trunk....
  6. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    But note that from above guide it is possible to register SIP client:
    For testing purposes, download a SIP client like yate and setup your username, password and realm, you can retrieve your endpoints as follows.
