russywhite
- Joined
- May 5, 2021
- Messages
- 10
- Reaction score
- 4
I am really struggling to get our test 3CX box to connect consistlently to BT HSIPT through Daisy in the UK, it connects and then after a while disconnects and we get the following messages.
When it does connect I cannot make outgoing calls but i can receive calls, does anyone have a config guide for 3CX to BT HSIPT?
I have spoken to Daisy who have been some help but I still havent solved the issue.
Thanks in advance.
- Call or Registration to xxxx.xxxxxxxxxx has failed. sip:10000@xxxxx.xxxxxxxxx replied: 403 Forbidden; from IP:62.7.201.169:5060
- Trunk L:10000(xxxx.xxxxxxx) has changed status to unregistered. This means that no more calls will pass via this trunk. Please check your network connection and the voip provider or other SIP PBX
- Trunk L:10000(xxxxx.xxxxxxxxxx) has changed status to registered.
Thanks in advance.
