3CX and Charter Communications Phone Service
Discussion in '3CX Phone System - General' started by dvs4man, Nov 1, 2009.
  1. dvs4man
    Oct 5, 2009
    50
    Has anyone out there got the 3CX PBX system working with the Charter Communications Phone Service?
    If so, can you share any configuration settings required to make this work?
    Thanks.
  2. StefanW
    Jun 2, 2009
    1,222
    93
    can u provide me with a username password and registra to check it out?
    u should got this from them.
    Just pm me the details and i have a quick look, maybe something is wrong with your network just to confirm...
  3. dvs4man
    Oct 5, 2009
    50
    I have not registered with them yet. I am thinking of them as an option, to see if there is any connection to them.
    If not, I can go with Broadvoice - they can port my number successfully, while Callcentric I like and have this PBX working with them on a trial basis, they cannot port my number.
    I am assuming that means there is no support for charter?
    Is the Broadvoice service working fine for everyone else who uses it? I have it installed on my PBX already.
    Let me know.
    Thanks.
