Solved 3CX and Cisco 8861 - Provision Unsupported Phone?
Discussion in '3CX Phone System - General' started by Robert Juric, Mar 10, 2017.
  1. Robert Juric
    Jan 14, 2017
    11
    I have been able to get a config to load on a Cisco CP8861 and I am able to see it listed on the 'Phones' configuration. It's correctly recognized it as a CP8861, but the MAC says UNPROVISIONED. When I try to add a phone, there is no option for a 8861, or "other".
    Is there any way to provision an unsupported phone?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    This phone can be provisioned by Asterisk, this generally should mean that you must be able to provision it with suitable template.
  3. Robert Juric
    Jan 14, 2017
    11
    Thanks for mentioning the templates. I found the blog article about creating a custom template. I basically copied the Cisco 79xx template and replaced the models. I'm 50% operational now. The phone shows up as registered in 3CX, but it is highlighted red. The phone will ring as part of the ring group for the extension for incoming calls.
    However I cannot dial out on the phone. I pick up the handset and get a dialtone, but the first key I press errors out. I'm sure this has to do with the phone config file, but I'm not sure which part to dig into?
    Edit, I see the first digit dialed in the 3CX call logs, but I'm not able to complete the dialing process from the phone.
    #3 Robert Juric, Mar 10, 2017
  4. Robert Juric
    Jan 14, 2017
    11
    Ok another strange thing. If I hit the down arrow on the phone phone for a new call, without going off hook. I can enter the full number, hit 'Call' and it rings out successfully.
    So its only dialing while 'off hook' that isn't working. Does anyone have any idea on similar phones as to what I could look into?
  5. leejor
    10,375
    231
  6. Robert Juric
    Jan 14, 2017
    11
    That was exactly my problem/fix. For the amount of time I wasted I would have thought it would have been more complicated than that.
    Thanks for the find!!
